メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Wifi Greyed Out and Repair Steps Completed
I've completed the following steps to no avail for my iPhone 6 Greyed out wifi:
1. Updated version to latest
2. Restarted phone
2. Reset wifi network
3. Restored to factory settings
4. Replaced wifi antenna
None of this worked. I don't want to pay Apple for repair or a new phone. Do you think replacing the motherboard might work? That is a heck of a lot cheaper than the options Apple has to offer.
Everything works fine on the phone except wifi and Bluetooth. Thank you for your time.
Respectfully,
Mike
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
4件の回答
最も参考になった回答
Do not replace the MLB, it's a waste of money. Try to repair the MLB instead.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
My WiFi was greyed out and my Bluetooth was also not working on my iPhone 6 so I replaced the WiFi antenna flex cable and then my WiFi and Bluetooth both started working.
This seems to be a pretty common problem but nearly all of the youtube videos and websites are rubbish.
iPhone 6のアンテナフレックスケーブルの交換
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
It's the wifi chip, common problem but not so much an easy fix, it requires soldering skills time and effort, best bet is YouTube iPhone 6 wifi chip replacement and that'll tell you where the chip is on the board,
Hope this helped
Regards
Lucas
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
There's maybe a different thing you could do but it's strange and probably not advised, heat your phone up with a blow dryer until the temperature warning comes up the put it in the freezer for like 2 mins I've heared it's helped but definitely would not recommend !
さんによる
コメントを追加
So when your wifi is greyed out its an issue with your wifi/bluetooth module or usually surrounding small components (possible capacitor not at right temperature).
Heating the wifi module isn't something I'd recommend as these wifi modules hate heat.
Was the phone liquid damaged or exposed to extreme heat?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Michael Sims さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,269
