The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
193の回答 すべて表示
Replacement for rubber feet located at the upper back plate
Are there any website that sells rubber feet located at the upper back plate of the device? If not then is there any way to make it adhesive enough without using liquid-based adhesive like superglue?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
当社のショップを閲覧する
1回答
最も参考になった回答
Hi @faux I got the easiest solution for you and here you go. http://www.amazon.com/Self-adhesive-Clea... I use these alot and even though they are clear they do the exact same thing and all you have to do is peel them off and stick them to whatever I use them on electronics, tool cases, Ifixit 64 bit kit and what ever I don't want to slide which is what those original feet did but they are just clear instead. I hope this helps
この回答は役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
J Gab さん、ありがとうございました!
統計データを表示:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 11
今までの合計 421
