メインコンテンツにスキップ
The Hamilton Beach Classic Stand Mixer (64650) released in December, 2011
7の回答 すべてを表示
Why is the speed lever stuck in place?
My mixer is plugged in and will turn on if I press the quick burst button but the speed level seems to be stuck in place.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Not to worry, it is possible that your mixer may just need a good cleaning. If you spilled an excess of liquid onto it, it is possible that the slider has been stuck in place by the liquid. Cleaning the slider from the inside of the handle may fix this problem and allow the slider to move with ease again. If your problem persists it is possible that a piece of the slider could be missing or a part of it is caught on something inside the mixer’s handle. To fix this issue you will need to replace the mixer's speed lever, by following this speed lever replacement guide.
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
David Ferranti さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 57
