Are the hard drives compatible
Will a hard drive from an iBook g4 work in the iBook g3?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Yup, all iBooks use standard ATA (as opposed to serial ATA, i.e. SATA) hard drives, so you're all set.
このアンサーは役に立ちましたか?
Yup, you will also see this referred to as "Parallel ATA (PATA)" or just 2.5" IDE.
True. It's funny though how the "parallel" ATA name was retro-actively created when SATA came around, i.e. back in the day there was only ATA, or IDE, and no "parallel" distinction.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,062
