メインコンテンツにスキップ
The Dremel 8220 variable-speed cordless rotary tool offers the highest performance of all Dremel cordless rotary tools. Released Date: June 22, 2012
Why is my Dremel overheating?
So I've been using this device for about 3 hours and within that time I needed to charge the battery. When i did that I used it again right after and while I was using it, the device seemed very hot, the battery specifically. What's wrong with my device?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
My flex shaft is getting hot, not the actual Dremel. The flex spring is very hot after about 10 minutes of operation.
さんによる
コメントを追加
3件の回答
ベストアンサー
1. You used the device for a long period of time and the battery really got hot, just turn it off and use it again after 20-30 min.
2. Your fan that cools the device might be broken. The fan is what cools the device and stops it from overheating. If broken just remove the fan and add a new one in.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
I live in an Apartment- I found out on mine, It was my problem… I was runing it at to low of Speed. To keep the sound down….. End of my motor.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
They use a TO-220 MOSFET inside with a terribly small heatsink and a small glueless mating surface between the MOSFET and the heatsink with a loose rivet. The MOSFET can get too hot and blow (small puff of smoke, sparks…etc.) I just ran into this myself. I’m going to have to desolder the MOSFET(s, there is a second one beside the TO-220) and put them on a better heatsink, properly mated as well. …Conveniently a month after the warranty expires.
*Edit* For anyone needing to replace the electronic assembly inside, the part number is 2610005464.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Meeley Bien Aime さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 45
今までの合計 8,528
