Why is my Touch Screen not working?
My touch screen does not register finger placements on the screen.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Screen protector Interference
Your screen protector may be the cause of the issue you are having. Remove your phone case and then proceed to use your touch screen. If your phone registers your finger placements, then your screen protector was the cause of your problem.
Screen is Locked
If your screen is stuck on one image and turns unresponsive, it is usually a software issue. Powering the phone on and off is a potential solution. If the phone’s display does not stay on or come on at all, then the lock button could be interfering. Try wiggling around the lock button or taking the back cover off the phone to see if there is anything interfering.
Screen Cracked
If the screen is physically cracked or damaged, then a replacement is usually the only fix here.
このアンサーは役に立ちましたか?
i bought a tablet at wal mart
i bought a tablet from wal mart in 3/5/16 and i didnt know it was damage until my daughter came home from her trip on 3/27/16 that when we found it was damage and took it back to wal mart they wouldnt replacement cause the 15 day warrant was up how can i get replacement for it i even have the recipt to
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 8,296
