The LED light on my Camera won’t turn on.
I've tried to take videos during the night time but the LED light wont turn on
Your camera’s LED light might not be turning on because the battery on your camera is low and needs to be charged in order to use it. Another possibility is that the LED light on your camera may also need to be cleaned in order to see the light. However, if the light is broken, the LED light may need to be replaced entirely.
このアンサーは役に立ちましたか?
The camera's front LED light might have blown a fuse if on for an extended period of time. Also the light might not be fully touching the connections where it is attached to an internal circuit board. This would cause a break in the circuit that provides it with electricity and therefore it would not work. Also as Jeffrey said, it might be on but it could just be dirty.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 82
