What to do next
Need to know the next step(s) after the hard drive pic appears with an up arrow beneath the pic. It wants me to do something but I don't know what.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
lumloy371 try this:
System Prefs>>> Start-up Disk. You have to make sure the OS X folder/drive is selected. It seem like your computer does not quite know where to find your OS. Of course it could also be that the Option key is being pressed at startup, or a setting which can be cleared by pressing the Option, Command, P, and R keys at startup, and releasing them after the second chime.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 61
3 件のコメント
This is for a MacBook A1181
lumloy371 さんによる
Are you installing an application? If you are it wants you to grab the application ICON and drag it to the HDD ICON.
Brian Reeder さんによる
Thanks Brian, but this isn't an app install. Just a failure to boot normally.
lumloy371 さんによる
