メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
My screen wont let me swipe, what should I do?
When I push my home button it lights up but when I try to swipe to get to the password screen it wouldn't move it. And I tried to do a hard shutdown and sometimes it works and sometimes it doesn't. When it does work it, it lets me get into my phone and then it wont let me move or get into somethings.
Please help!!!!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Did this happen following a repair, a hard (or not so hard) drop, liquid spill? Any incident?
In any case, there are 2 possibilities I can think about until you tell us more about the history of this device. If your device is out of warranty, here's what you can troubleshoot:
- Screen gone bad. Trying on a known good screen will confirm or rule out this possibility. Here's a guide that shows you how to try on another screen. It needn't be new, it can even be cracked, but it just needs to be known good. Alternatively test your screen on a different known good device.
- If a known good screen doesn't solve it, the touch circuit (and most probably a touch IC) has failed. In that case it stops being a DIY repair and should be taken or sent to a reputed repair store (it's a totally doable repair but at the same time easy to botch if the technician is not experienced enough) that can do micro soldering repairs or that subcontracts them to micro soldering experts.
If failed touch circuit does indeed turn out to be your issue, you can also have it replaced out-of-warranty at an Apple Store (provided it was never repaired by someone other than Apple before); but you'll loose your data in case you don't have a current iCloud or iTunes back-up. It's also your most expensive option, though guaranteed to get you back a working device.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
If it's not a software issue then it is clearly related to a faulty digitizer or its connector.
You can first try unplugging and cleaning the digitizer connector and see if the problem still persists. If so, I'm afraid you will need a new digitizer.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Grace さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 41
今までの合計 9,274
