メインコンテンツにスキップ
Version 2 of Parrot's toy quadcopter with HD camera, controlled over Wifi by smartphone.
24回答 すべてを表示
How can I fix my drone after crashing into water?
My AR Drone 2 has crashed into water. I put it for a week in a tight plastic bag with some rice trying to dry it out. However, seems something went seriously wrong as when I connect the battery it didn't respond at all.
Now, first how can I tell which part has been damaged?
second: what is the best way to fix that?
Many thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
Putting it in rice may have ruined it. Its food not a solution. Find someone that does micro board repair.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I have faced the same situation when my DJI drone has fallen into the water. I have tried some basics steps at my own risk.
1) Turn the power off and remove the battery.
2) Check your warranty: If your drone is still covered by the warranty, there’s little more than you can do except put it in a dry, warm and ventilated place until you can send it off to your supplier or 'best drone repair shop for DJI Drones'
3) Towel dry the rest of the device.
4) Put the device in the oven at the lowest possible temperature, 125F to 175F, for several hours. This will dry any remaining moisture in the device. Do this as soon as possible. These temperatures are above the 104F that DJI recommends.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
How can you solve your problem put it in the oven? I should read about how to repair things with liquid damage. Drying the water is as bad as putting it in rice. Inform yourself before giving this type of answers, is misinformed and is misinforming people who may not have much idea that is effective or that will damage your device.
If something is wet and you want to repair it, read this please: Electronics Water Damage
さんによる
コメントを追加
try to give the motherboard a 100% isopropyl alcohol bath!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Amgad さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 1,057
