メインコンテンツにスキップ
The first generation Honda CRV, produced from 1995 to 2001.
97回答 すべてを表示
Why has my door and rear door remote suddenly stoped working
1999 Honda CRV - the remote door opener suddenly stopped working. Did the obvious thing of changing the battery in the remote with no success. Checked the fuses still no joy. Any one have any other ideas??
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
seria bueno tener una altenativa de traduccion,.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hi,
It may be that the remote button 'contacts' have worn out through use over the years.
Here is a link that shows how to clean the buttons on a TV remote control unit. The principle of operation for key fob buttons is the same, so perhaps you could check your remote key fob and see if cleaning the contacts solves your problem.
https://www.youtube.com/watch?v=DBBJlGFU...
Alternatively if cleaning doesn't work, you could try re-programming your keys with the car. You will have to do all the keys for your car as re-programming only the one key renders the others useless.
Here is a link that shows how to re-program your keyless remote.
Pause the video before it ends and then click on the Show More link below the video screen to see the programming information. Take note of what happens to any other keyless remote(s) that you have for the vehicle, once you start to reprogram your remote. You have to reprogram them all.
https://www.youtube.com/watch?v=osPj0GFL...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Rod Matthews さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 184
