Why won't my device turn on?
The device remains off even when I slide the power switch.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
First, you should be sure that your device is charged and the charger does not show any signs of wear or malfunction. If everything seems to be functioning normally, be sure that the battery is charged. If the battery will not charge, you may need to replace the battery, for which there is a guide for this device.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 3
今までの合計 888
