メインコンテンツにスキップ
The ZTE Speed is a full keyboard touchscreen smartphone powered by Android. Model number: ZTE N9130.
22回答 すべてを表示
Why won't my phone charge?
I am having trouble charging my phone and i don't know why it won't charge?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
First, check that the charging chord is not damaged in any way. If the chord is unbroken, check the contacts at the end of the chord for burn marks. If there are burn marks on the contacts, then the charger has short circuited and will need to be replaced. If the contacts are in good shape, then check the phones charger port. Make sure it is clear of any debris. If you see debris in the port, such as lint, use a needle-like object to remove the debris from the port. If none of the above apply and your phone does not charge, then the battery is faulty and the phone will need to be replaced as the battery is embedded into the motherboard.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
First check that the caring unit is correctly installed into the wall and phone. If the problem still persist try taking the battery out and powering on again. If this still doesn't work it would be best to replace the connection of the charging unit.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Chandler Mitchell さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 3
今までの合計 1,583
