Wifi ic removed and solder pad riped under
Removed the wifi ic in attempt to remove it 2 pads broke off what can I do to repair it or jump it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I can help just post a pic of it
このアンサーは役に立ちましたか?
Just added the picture, your help would be much appreciated.... thank you
Ok thanks give me few minutes
Unfortunately the pads you rip off leads to the power management ic and CPU most likely your bluetooth won't work or the wifi will be grey out. You will have to scrape those pads to find copper to make a trace to make it work again.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 215
