メインコンテンツにスキップ
Repair guides and troubleshooting for the Whirlpool Quiet Partner II insulated dishwasher.
46回答 すべてを表示
Clean light still blinking 7 times after I installed a new element
Whirlpool quiet partner ii clean light flashing 7 times. I installed a new heating element and reset the code, and it still flashes 7 times
Not sure what to do now?
Any help will be appreciated.
Thanks
Chris
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I have the same issue - once it was replaced, it is heating the water but after the rinse the light will flash again 7 times. I have reset but still have the. BLinking light
さんによる
コメントを追加
1 件の回答
ベストアンサー
The flashing "clean light" indicates, a water temperature, heating problem.
It could be due to, a bad heater element, thermostat, or a control board.
Most of the time, it's due to a low water temperature.
You need to make sure, the water temperature, in the bottom of the tub, on the first fill of a wash cycle, is at least 120 to 130 dgrs. F. (you should be able to run the hot water faucet at the kitchen sink, and get somewhere in that range, before you start the dishwasher).
Read more: http://forum.appliancepartspros.com/dish...
http://www.appliancepartspros.com
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
chrisandhelene さん、ありがとうございました!
統計データ:
過去 24時間: 9
過去 7 日: 67
過去 30 日: 305
今までの合計 14,293
