Which OS should be installed when upgrading from Core Solo to C2D
High! Just the other day I upgraded a Mini 1,5 GHz Core Solo to a 2,2 GHz C2D, running OS X 10.6.8
It worked out perfekt, the machine recognized it and runs well. Step 22. in the tutorial says : 'Note that if you are upgrading from a core solo or core duo processor to a core 2 duo processor and wish to run operating systems of Lion or later, you must delete the hidden file /System/Library/CoreServices/PlatformSupport.plist after the upgrade.'
I ran iVisible & EasyFind, but no such file!? Now Im unbable to install a higher OS version.
Wich OS should be installed, to find this file. Originally it came with 10.4.5. Do I have to go back there?
THX for help, Greetings from Krautland
この質問は役に立ちましたか?
