メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
apple logo flash then black, backlit screen
Ok so, itried fixing a water damaged iphone 5s today and did the whole alcohol thing. so i put the motherboard in and tried turning it on... nothing. so i plug it in then i get an apple logo for about half a second then it switches to a black backlit screen and stays there. maybe i didnt remove all the corosion and need to clean it more? by the way i did plug it and itunes recognizes it and i restore it... i get an error code 3194. right now i am stuck and have no clue what to do because i spent a lot of money for the parts. I know the parts are 100% working because i tested them on a different motherboard. also lastly my phone doesnt turn on unless its plugged in.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
I have the same problem, tried the solution and it doesn't work, what next?
さんによる
コメントを追加
4件の回答
ベストアンサー
DFU Mode
1. Plug your device into your computer.
2. Turn off the device.
3. Hold the Power button for 3 seconds.
4. Hold the Home button without releasing the Power button for 10 seconds.
5. Release the Power Button but keep holding the Home button.
6. Keep holding the Home button until you are alerted by iTunes saying that it has detected a device in Recovery Mode
Make sure the device screen is blank and no logos are present.
Restore the phone :)
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
i have plug my device into the computer but unable to turn off the device... keep on and off showing apple logo and black screen
さんによる
it does not allow me to do this it just flah back very quickly
さんによる
コメントを追加
i tried that but when i am plugging the lightning cable on my device it flashes apple logo then leaves backlight on. the itunes also automatically detects the phone on recovery mode please help
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I'm having the same problem. Can't find any information that's actually useful. I did find out though that the iPhone has been opened before given that it had a sticker inside it which read 'happytel' I'm guessing this one may have been repaired for water damage. It's difficult to find solutions for these things. I'm going to try exchanging parts with another iPhone I have but don't have much hope.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I had this problem a while back your battery is bad
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
did you change it and does it works
さんによる
コメントを追加
回答を追加する
christian lopez さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 27
今までの合計 23,671
