メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2013年9月10日に発表されたApple iPhone 5cの修理情報とガイドです。モデル A1532, A1456
iPhone 5c Microphone doesn't work
A little while ago the microphone on my iPhone stopped working. There must be two mics, because phone calls work, but calls on speaker phone, Siri, etc don't work.
I'm going to be replacing my screen anyways, so I thought it might be a good opportunity to replace the microphone. But I can't find parts or a guide for such on here. Is it included in another set of parts or something? What can I do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
That mic is located on the front facing camera cable. It's pretty easy to change that cable as part of the screen replacement.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Rich is correct. most likely needs replaced but the earpiece mesh can get also fairly blocked up which also includes a hole for that mic. if you remove the screen and that part then take a look at behind it, hold screen up to the light and you should see light pass through it. if not then scrape the mesh from the inside and outside with a fine pin etc to allow more sound to pass through.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Evan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 266
