メインコンテンツにスキップ
モデル番号A1225 / Early 2009 / 2.66, 2.93もしくは3.06 GHz Core 2 Duoプロセッサ
164回答 すべてを表示
締切られた回答
Burned out ethernet port
iMac 9-1 Early 2009 2.66 Ghz
Lightning ran in on my machine through the cable modem...am now using USB to ethernet adapter from Apple and all works well.....just wonder how much it would cost to get a new Logic Board for the ethernet if available?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
I think I picked the right machine icon.
Here are the A1225 machines that the logic boards should work from:
http://www.everymac.com/ultimate-mac-loo...
You know the old adage "if it ain't broke, don't fix it,"
It's working, so I wouldn't risk a major overhaul just to gain one USB port. Machines hit by lightning can have component weakening. Personally I have a 2009 MacPro that was hit and I put PCI USB & PCI ethernet cards in it to get it running. It is still running.
I would have an external backup hard drive and keep Time Machine backups.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
In this situation you have to replace Ethernet port.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Sadly, the Ethernet port is part of the logic board so it's not replaceable. But, one could use a USB Ethernet adapter if you can find one that is supported under OS-X which the OP did.
さんによる
@danj - Dan, that's what he's using now.
さんによる
@mayer - Yep! "Which the OP did"
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 668
