メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
The HTC Desire 700 Dual Sim has a 5in qHD display with a quad core 1.2 gH processor.
6の回答 すべてを表示
Phone is not getting charged and getting turned on?
My phone was not getting charged when I plugged in the charging cable...the battery was 75% at that time...I thought I will switch it off to again switch on but it won't happen... It is not charging and not getting switched on also and there is not light also..no orange no green...Please help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi Deveta
Maybe your battery is faulty. If you could replace the battery with good one and see if it turn on.
Good luck
この回答は役に立ちましたか?
スコア 0
コメント:
Hi...actually i got it checked ..there was no major issue..it only required a booster for the battery and ya it is working perfectly fine without loosing any data
さんによる
So maybe you have software problem. If you could find someone to repair the software it may work. good luck
さんによる
コメントを追加
回答を追加する
Deveta Singh さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 162
