Will boot fine to safe mode, but not regular
MacBook Pro 15" will boot with chimes. Blue screen but no icons, no mouse pointer. Just a blue screen.
However, I can boot to Safe Mode with all icons and mouse pointer. I have done a disk check and a verify permissions check. Nothing really major in the logs.
I tried to boot from DVD, but the drive just spits it out. I will replace the DVD drive. But I'm not able to boot it even with the DVD unplugged.
Any ideas?
Update
Found that the issue was two fold: The new cd drive helped the machine boot properly. I was able to reinstall the OS. Also, it turns out the FireWire port is bad. I did a little search on the intertubes and found that this can be overcome by moving the .kext files out of the Extensions folder. Because this machine is going to be used by my niece and she would have no reason to use FireWire, I went ahead and moved all IOFireWire related .kext files out and the machine is now functioning properly. The only issue I noticed was a problem with a little bit of a "stutter" in the OS behavior. When opening safari, the machine will hang slightly. I've watched for the logs, but find nothing related. I might have fixed it with the upgrade to 10.6.4...
この質問は役に立ちましたか?
4 件のコメント
It's become even curiouser. I cannot boot to target disk mode, and cannot boot from the USB. However, in safe mode, I can see the target disk and I can see the USB disk.
I have reset the PRAM and reset the SMC.
I have removed the ram and replaced.
Holding the option key or the T key do nothing.
I really don't want to invest 700 for a logic board.
Any thoughts?
Jason Luckey さんによる
Sometimes you need to take it to a pro. It will cost him. Take him some coffee and cookies for the pain you're about to inflict on him. Trust me, I'm a doctors son, coffee and cookies are worth $100 in free work.
mayer さんによる
Jason Luckey さんによる
Can you' please post the above as an update so it will stand out to others with similar problems.
originalmachead さんによる
