Why won't my device's battery charge when it is plugged in?
My device is plugged into a wall outlet via the charger. The charging cable doesn't appear to be damaged and everything else looks fine visually.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Mr Betts,
I would assume that the internal battery is damaged or old, and wont hold a charge. If the battery is in state of needing replaced then your device may not even turn on.
このアンサーは役に立ちましたか?
My battery is new & I noticed this morning when plugging in to wall socket....it actually notified it will not charge while turned on. I am currently waiting for replacement unit because of recall.
i have just replaced my tablet with a new battery and it is only charging 5%. what is wrong?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 14
今までの合計 1,250
