メインコンテンツにスキップ
This Power Mac G4 has Mirrored Drive Doors.
80回答 すべてを表示
Original Mac OS X Disc will not reinstall.
My Power Mac G4 started to run slow and slower, gave time and date messages to check it it would run . I put new battery in and two weeks later came up again. I decided to reinstall my original OS X Disc got about half way through the install and quit said it failed message, I tried it again same thing failed. Can you help.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Michael, please check the date on the battery first. It may have new but old stock. Were the date and time holding? Will it start in safe mode (hold down the Shift key on start up). This does sound like failed hard drive.
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
I tried the to in safe mode it opened in Mac OS 9.2??, but will not eject to accept a disc.
さんによる
Hold down option key when starting to select the system you want. The date is stamped on the battery. Hold down mouse button on start up (to eject it), or it will boot from the CD/DVD (which is probably what has happened and your hard drive may have failed already.
さんによる
Thank you for your answers. I believe I'll replace the Hard Drive, can you recommend a website to purchase part.
さんによる
OWC will carry those older drives. Here's a link to those drives: http://eshop.macsales.com/search/3.5+Int...
さんによる
コメントを追加
回答を追加する
Michael Farnsley さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 200
