What is making my LCD display turn white?
My camera's LCD display is completely white and unresponsive to any features I try using on my camera.
Your answer may lie in the simple hidden feature of your camera's settings. Go into your camera's settings and make sure your brightness is at an appropriate setting. If this isn't the case, you may need to remove the battery and memory card from the camera and hook it up to a computer via its USB to ensure the screen is properly working. If none of these solutions work, then you may potentially have a damaged LCD screen.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 68
