Why does the door take so much effort to open?
I seem to make a lot of effort opening the side door on my camcorder. I don't want to break it. Is the door supposed to take effort to open, or should I get this looked at?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The problem you are facing is very common for this device. If you have a DVD you must retrieve from the compartment you can pry open the DVD chamber with a spudger. Unfortunately the door may not be able to recover switch actuation with a simple troubleshoot. You may have to replace internal components specifically the the compartment's latch mechanism.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 58
