What is the name of this part of the display?
Here is a picture of the part that is broken:
It contains the camera and, I believe, the WiFi antenna, as well as the hinges and the cables. It has two numbers on it. FX02607-3832-06081021C and 08100825. Neither of which give me any clue as to what it is.
If I search for "display frame" I get things like this or this. Searching for "display hinge" just gets me the metal hinges and not the whole assembly.
Can anyone tell me what this is called or, better yet, where to buy one?
id suggest from what i can see its the display housing front
Alex Hus さんによる
@alexhus That got me a lot closer. I can find 2010-2011 display housings easily. Unfortunately, I need one for a 2008-2009. I found one on Alibaba but it also has the aluminum cover which I don't need. I would also rather not deal with Alibaba but I'm flexible there. Is there a specific name for the plastic frame without the cover? Or at least, a part number?
Kyle Williams さんによる
Are you talking about the front class or may it be the display support frame?
Alex Hus さんによる
@phoenixkc
MacBook Pro 15" Unibody Late 2008/Early 2009 LCDの交換
look at step 27 is it that piece?
Alex Hus さんによる
Is it broken on the left hand side about an inch up from the bottom?
mayer さんによる
