Which bits come with this Dremel?
Do you know what bits come with this Dremel? And where could I go to buy additional ones?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The 7300 comes with four bits a grinding bit, a cleaning bit with two different heads( A Wire-brush head and a pressed cloth polishing wheel), a sanding drum bit( with extra sanding cylinders), and a mandrel bit. The collet is a 1/8th sized one. You can purchase additional accessories from either hardware stores or online retailers.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 123
