メインコンテンツにスキップ
Easy to use camera for children, able to be mounted on bikes, skateboards, helmets, etc..
6回答 すべてを表示
Why is my battery not charging?
My VTech Kidizoom Action Cam does not charge when I plug it into my battery charger. What do I do so it will charge properly?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 11
19 件のコメント
So guys i had this problem too. Ok so looks like some have a usb port only to tranfer the photos off not to charge. These ones have small screws and you need to just change the batteries. BUT if you have the newer version like me then plug the usb charger in and turn the camera upside down. You will find the smallest on off switch in the world on the right side. Switch across and it will start charging. They make these toys far to complicated!
さんによる
before l slept, l charged my kidibuzz and it was working and when l woke up, it was not and it had 0%. I tried to charge it for a hole day, but it did not work. When l follow lots of the steps in google, it just does not work
さんによる
When i was charging my Kidizoom watch before I slept I charged it then the next day it was dead I tried charging it it doesn't work but finally it works now
さんによる
yeah it does the same when i go and see if it was at green IT WAS AT RED AND 0%
i tried eveything that didnt work and five mins later it WAS STILL AT RED THEN IT TURNED TO GREEN THEN I ASKED MY DAD WHAT HAPPED HE TOLD ME I BROKE IT JUST HELP ME PLS I WANT it TO CHAGE AGAIN PLS HELP
さんによる
I am trying to charge mine in the computer and there's no switch on my Camara it says on the screen Learning lodge kidizoom for one hour
さんによる
14件以上のコメントを表示
コメントを追加
7件の回答
ベストアンサー
Please make sure that the master power switch on the bottom of the device is placed into the 'off' position for the device to charge. If the device still is not charging the USB cable or battery may be faulty. The Troubleshooting page may be able to help you further.
このアンサーは役に立ちましたか?
スコア 9
9 件のコメント:
But it is said in the manual, the master need to be at the "on" position for charging.
さんによる
I am having same issue. I have 2, one wi charge the other will not. The one which does charge is in the on position.
さんによる
i have the yellow/black camera and the usb port is screwed up and i want to know if it's fixable or replaceable.
さんによる
Thanks for the help, I thought I was supposed to have it in the on position. :)
さんによる
I don’t know what the master power switch is
さんによる
4件以上のコメントを表示
コメントを追加
It will only charge off their usb cable, on any other micro usb lead the part that plugs into the camera is just to short. So it fits in but won't start charging.
このアンサーは役に立ちましたか?
スコア 5
1件のコメント:
When I plug it Ito just says pc connected it doesn't charge
さんによる
コメントを追加
It’s not rechargeable. Remove the screw from the side of the camera and remove the orange silicone. Replace the 2x AA Batteries. Manual is incorrect
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I had the charging problem with 2 watches, I decided to change the plug the USB was in from a fast charge to a normal charge and it worked, both charge fine hope this helps someone
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The master power switch has to be on for it to charge and mine, I plugged it into the wall with the cable and the adapter, which is from another thing, and I haven’t seem to be the camera has not been working I plugged it in. It still works but doesn’t charge.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Also having the same trouble, plug it in to charge and it says 'turn on the battery switch before charging'. It says this whether i have switched underneath to either I or O. Any ideas please? Has anyone solved this problem?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
if master Switch is in the on position and still not charging… make sure you are not using a fast charger plug and use the cable that came with the camera if possible or try another charging cord
That should solve charging issue.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Anthony Teresi さん、ありがとうございました!
統計データ:
過去 24時間: 29
過去 7 日: 223
過去 30 日: 902
今までの合計 97,768
