Why can't I hear when I plug in headphones?
Why can't I hear any music when I plug my headphones in?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Make sure the headphones being used are completely plugged in. The headphones being partially plugged in can cause low sound quality or no sound at all. If you are still not hearing any audio after checking the plug, try using the headphones on another device. If the same issue persists, try using a different set of headphones as they might be faulty. If audio issues continue with functional headphones and they are plugged in fully, then it is possible the headphone jack might be faulty. In this case, the headphone jack probably needs to be replaced. Amazon Fire HD 10 Troubleshooting Guide
このアンサーは役に立ちましたか?
it's not working i still can't here nothing this stuff doesn't even work
Lick the head of the plug in and insert, for some reason the contacts are connecting very well. That did the trick.
このアンサーは役に立ちましたか?
Thank you soo much!! I would’ve never thought to try that !!
What that acctuly worked0_0
Why did this actually work LOLL
its not working
このアンサーは役に立ちましたか?
Once I use the head phone plug thru my receiver on my tv no problem once I plug fire stick I don’t get any voice
this hack is a fail my headphones are still not working
過去 24時間: 20
過去 7 日: 129
過去 30 日: 616
今までの合計 38,896
check if its muted, unplug your headphones and see if there is even sound coming out of the device/
Spoofo9t9 さんによる
The sound comes out of the speaker when i play it but when i plug my earphones on i dont hear anything
Fayeza Raheem さんによる
I had same problems as yours@Fayeza Raheem..I don't know why...I can't hear anything when I plugged in my wired headphone..when I unplugged it..I can hear the sound came from speaker
Silmina Zahra さんによる
I would try using a soft bristled toothbrush to clean out the 3.5mm headphone jack. I'm assuming you've tried a different set of headphones...
TYLER GOODWIN さんによる
It seems that the headphone jack in non-functional. My earbuds work fine with my laptop. The connection feel very loose when I plug in to the tablet. I suppose there's no way to open the tablet to replace the jack.
Douglas Robertson さんによる
