メインコンテンツにスキップ
Nexus 6はGoogleとMotorolaによって開発されたAndroidスマートフォンで、6インチディスプレイを搭載して2014年に発売されました。
68回答 すべてを表示
wifi stuck on "turning on wifi"
how can I fix my wifi card that stuck on "turning on wifi" with 02:00:00:00:00:00 as mac address
PS: bluetooth work without probleme
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント:
Tried going back to stock LP, doesnt work. Tired going to custom roms as well, doesnt work either. Tried going back to 6.0.1, gaing root, and then using those Change My MAC apps, doesn't work. Tried your delet wifi folder method, doesnt work.
さんによる
コメントを追加
2件の回答
Hi, Sounds like your wifi chip has broken, it will most likely need to be fixed buy a professional micro solderer.
Good luck
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
No, nothing hardware related, Was a software issue, already reported by several users in Google and motorola forums.
Even Motorola support recognize it but said that they will not covem me just because I live in Argentina.
Finally I've sold the phone with a huge discount and will never bought a motorola phone again.
さんによる
コメントを追加
have the same &&^&^$^ trouble
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I've tried several distributions and found that with the ones based on CM this procedure works (Not with official OS).
1- Turn all radios Off. (Airplane mode)
2- Turn Bluetooth on, and wait until it was effectively turned on. If also stuck turning on restart the phone and go to 1 again.
3- Once BT was on turn wifi on, you will have all radios on but GSM one (will take a bit but in most cases it works)
4- You could try now to turn off airplane mode, and have all radios, but sometimes it makes my phone inestable, sometimes wifi was disconnected and even phone rebooted.
Good luck
さんによる
コメントを追加
回答を追加する
hzami ahmed さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,356
