メインコンテンツにスキップ
2012年初期に製造された13インチ Retina DisplayのMacBook Proモデルです。
3725回答 すべてを表示
Screen lines stripe when temperature is cold?
hello everybody !!!
my problem is when my AC is on and the temperature is colder my A1502 screen has horizontal lines , i am obliged to open all my applications to make the processor warm and afterward it's okay , i would like to know how to fix it? please
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
10件の回答
選択されたソリューション
I have this exact same problem with the exact same model. Did you ever find a solution? I am considering replacing the LCD, but don't want to do it quite yet. Please let me know if you solved it.
このアンサーは役に立ちましたか?
スコア 0
コメント:
This video gonna help you fix It https://youtu.be/12dVmqLn644
さんによる
コメントを追加
The same problem. Please write back if you've solved this/
このアンサーは役に立ちましたか?
スコア 0
コメント:
you have to install the Program and go to Fan>Manual>slide it to Right to warm you computer. and he gonna be stop flickering
さんによる
さんによる
コメントを追加
Yeah solve the problem at 50% i see the display line screen problem happen when my mac is cold i use an app : TG PRO TEMPERATURE to boost my processor and after 2-3 mins bossted everything doing good and i can use my mac, or i open the app required a lot ram processor to warm my processor and after i can use it!!! If someone have a better solution let me known :)
このアンサーは役に立ちましたか?
スコア 0
コメント:
さんによる
コメントを追加
Somehow the LCD froze up when starting my PC. Took it down to the Apple Stores ran all sort of diagnostic check all passed. Its the cold weather every time I start its froze and clears out about 5 mins. Went to Fiji south Pacific for 2 weeks it works every day when I was there weather was warm and average 85 deg. Got back to Seattle it back to same thing again. So Ive been warm it next to my stove and it clears up right away. My Imac Pro 13" only 11 months old.
このアンサーは役に立ちましたか?
スコア 0
コメント:
Like i posted earlier there a program name TG pro. You can run you processor fan manually so thats can warmup your computer and les 15 min. Instead put u computer next to. An heater or oven ! The battery can explode! Buy the program and solve that problem thats the only way i solve it
さんによる
コメントを追加
このアンサーは役に立ちましたか?
スコア 0
コメント:
さんによる
さんによる
コメントを追加
I got my macbook air about 2 weeks ago. I was playing music on it and then these lines just popped up. I cant seem to get rid of it. Help!!!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I had to replace entire screen. The problem just kept getting worse. It was expensive but fixed the problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have the same problem and it’s the retina display temp not the processor temp. If you record the flickering screen with quicktime then play it back when the screen has warmed up, no flicker!
I affixed a piece of neoprene foam rubber to the back of the display and max out the brightness for 10 mins. It acts as an insulator and the screen warms up quicker.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Is there another solution for that problem meanwhile? I have the exact same issue with my 13” Retina MacBook Pro from Mid 2014. When it’s cold on startup the screen is flickering. After a few minutes it stops.
I mean, is there any solution, to stop that flickering on startup, even when its cold? Except for replacing the display for 350-400€?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My Acer Aspire V3-572G started doing this about 4 years ago after the fan failed while gaming. Didn’t really notice it for a while other than when It was really cold, because it heated up fast with no fan. Also, the GPU is further away from the heatsink than the CPU, so it got hotter quicker. Once I purchased a new fan a few years back the lines on the screen stayed for longer and longer because the fan was keeping the GPU cool. I use this computer for school and it is very annoying, as it lasts about half an hour, and when unplugged it uses less power to save battery = less heat.
About the battery saver, when unplugged, the laptop switches from 840M to integrated graphics, but it doesn’t seem to make a difference.
I think it is a cracked solder joint on the chip, and I checked the internal cable connector but it was fine. Flexing the entire keyboard or the screen makes no difference. The lines do not appear on an external monitor, so I am on the fence whether it is a monitor or GPU issue.
Yes, the laptop is 7 years old, and i think it needs to retire. (writing this from the laptop)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
IZI Tuto Buissereth さん、ありがとうございました!
統計データを表示:
過去 24時間: 4
過去 7 日: 61
過去 30 日: 264
今までの合計 11,588
