メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
締切られた回答
iPhone constantly searching for carrier (no service)
I have this iPhone with a badly broken screen. The lcd still works. The phone is not bend so the motherboard looks ok. Only problem is the phone keeps searching for carrier. what could be the problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
First, check the time and date is correct, as this can cause this issue.
Second, check that the IMEI and Modem Firmware is visible in settings. If it is not, you have what's called a baseband issue, and the device needs board level repair. There's a link on my profile for a website of trusted techs if you wish to find someone close to you.
If both of those things are OK it may still be a board level issue (iphone 6 are very common for cellular IC fractures) but it definitely needs to be investigated further by someone experienced
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 219
