メインコンテンツにスキップ
モデル番号A1286、発売日 2011年2月/2.0, 2.2もしくは2.3 GHzクアッドコアIntel Core i7プロセッサ
576の回答 すべて表示
Screen connector replacement or screen assembly or logic board
Hi
My friends MacBook display stopped working a while back (still displays on external)
he took it to a repair shop and they reported that it need a new display assembly.
now I opened it and when I put it back together it was working but as soon as it got moved or had any vibration it would stop.
so I can clearly see the screen works and the output of the logic board seems fine.
what my main question is can I just replace the display connector?
or does it have to be the display assembly?
thanks alex
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
PCラップトップ用バッテリー
iFixitの品質保証付きトップPCブランド用バッテリー
ショップを見る
PCラップトップ用バッテリー
ショップを見る
1回答
選択されたソリューション
You'll need a heat gun to remove the glass. It obviously works but may or may not be the cable. Make sure the contacts and receiving port are clear and no corrosion on the contacts ob the display data cable.
Before doing this, please take it to an ASP and have it tested for this issue (free) and very possibly your solution:
https://www.apple.com/support/macbookpro...
The check your coverage link only identifies your machine, not your coverage for this issue.
この回答は役に立ちましたか?
スコア 3
コメント:
ok thanks it seems to be the cable as I had the bottom of the mac off and was "playing" with the cable and the screen was on and off
による
Just an update
Whilst I was inspecting the screen connection I saw that the screen cable had 2 wires that look like that had a internal brake
So I cut a small section out and soldered it
It seems to of fixed the problem
による
コメントを追加
回答を追加する
Alex Hus さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 7
今までの合計 392
