MB will not charger after a soda spill
Well to start off, I spill soda on the keyboard. My first reaction was to pull the charger and a quick shut down.
Now I've disassemble the whole book to pieces and cleaned everything out. I then reassemble the book back after a week of drying, and everything worked fine, you name it bluetooth, airport, superdrive, usb's, ethernet, etc,. I didn't think to check the charger until I was at 50% of charge.
When I connected the charger there was "no" "light", so I check the power reading and it recognize the battery and it's health but not the charger being plug in or the battery being charged. So I look up some trouble shooting I could do like resetting SMC, PRAM, no luck. By then my battery was at 25%. So I did the next think in mine to clean the contact of battery and DC board. No luck once again, so a bought another DC board hoping that was the issue. No luck again. Now it when to battery reserve power so no more testing for me. Now the MB work great the logic board just has that issue of recognizing the charger and charging the battery. Does anyone else know if I missed something? I did have Apple check the charger they gave it a green light. (By the way if your having a issue with your charger like the wires exposed, apple should be replacing those for free of charger, but they will ask you for the model # so make sure you have your serial # at hand). Has anyone had there logic board fix just for the charging issue? if so how bad was the issue? I do think that replacing my logic board will be a waste of money.
1件のコメント
Well if you choose to replace the $665 logic board first that's certainly your prerogative, but be advised that it may not fix the problem.
mayer さんによる
