メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The Samsung Galaxy Tab 2 10.1 is a 10.1-inch Android-based tablet computer and belongs to the second generation of the Samsung Galaxy Tab series.
Screen is constantly flickering in purple/pink - what part is broken?
My galaxy tab 2 10.1 has a broken glass but has been working fine anyway. Now suddenly the screen is constantly flickering in purple and pink, the picture is at the same time jumping around, the lines making up the screen jumps at different directions, making it impossible to use. But the touchscreen responds, although I have to guess what I am touching when I can't see what's behind the flickering and jumping screen.
I wonder what part is broken, so I can try fixing it?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
The flickering is caused by a broken lcd panel. If the touch stops responding the digitizer would be the broken piece. However large displays usually have both the digitizer and lcd bonded with glue. In that case it is easiest and quickest to just replace both pieces as a unit.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It's caused by a damaged lcd display, check following links for the replacement tutorial and replacement part if you'd like to repair it by yourself, hope it helps, good luck.
Tutorial: https://www.youtube.com/watch?v=-xT5B8GE...
Part: http://www.etradesupply.com/samsung-gala...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Sara さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 24
今までの合計 11,067
