How to avoid Yellow pressure marks on Loca Glass only Repairs?
How to avoid Yellow pressure marks on Loca Glass only Repairs???
After the glass only repair I get a yellow line around the edge of the screen, usually if I press down on the screen it will appear to disappear so I'm assuming its pressure on the LCD.
I have tried different cure times on the UV and 2 different lights. On is a 2 foot blacklight and one is fraud note checker you get in shops.
Doesn't seam to be any correlation. Anyone know how to avoid this? At first I thought it was the use of a compressor to remove excess glue from around the lcd after curing but it does it without. One time it vanished the next day and on another it appeared the next day from a good screen.
It is the last piece in the puzzle. everything else is ok.
Does removing a stray bubble cause this or pushing down to spread the loca out. But sometimes I didn't push down and it still happened!
Can it be putting too much?
Many thanks.
この質問は役に立ちましたか?
