メインコンテンツにスキップ
The HP Officejet 6600 Inkjet Multifunction Printer is a 4-in-1 device that can print, scan, copy and fax.
Can't send it receive faxes
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント:
What kind of connection are you using?
さんによる
コメントを追加
1 件の回答
Fax issues typically boil down to connectivity. Get a good quality phone cable, get it straight between the printer and the wall, check for a CLEAN dial-tone, free of static and crackling. Once you get that far, try a test-fax using the scanner bed.
Once you have THAT working, then you can move gradually into re-adding your existing hardware into the mix. Reattach that magical 20 year old splitter you have on the wall, see what happens when you test-fax again. Add that existing phone to the splitter, see if you can still test-fax. You can then try faxing from the PC in there's one connected.
ANY other error would be a problem that can be communicated via the front screen or an error window on a connected PC. Out of Ink? Printer not found? Paper Jam? Fax not configured?
I hope this helps. I did the best I could with the info I was given. :)
PS...need more concrete info on the question.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
lfindlay さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 221
