Help narrow down PS4 problem?
Was wondering if anyone could help me narrow down the problem with by PS4. Here is the details: the PS4 for the most part will beep, blue light will come on for a second then cut off. If you do this often enough it will then start alternate with a beep with no light and then a beep with blue light then cut off and then beep with nothing again. Sometimes the blue light will stay lit but nothing happens. Also every once in awhile it will come on and work for 2 mins or so and the screen will flicker and change color(think like lines of rainbows across the screen) then after like 2 mins the screen will go blank and the PS4 will apparently cut off but the white light will stay on. So many things going on I don't know what it is.
Edit: For the most part it seems to alternate between the "beep, then blue light then turns off" then "beep with nothing happening" in that order over and over. When it does work it's usually when I turn it on it's side or upside down and put pressure on the bottom of it. When it turns on once in a blue moon the picture is weird and the sound is distorted. I was thinking PSU but would that make the picture and sound weird?
この質問は役に立ちましたか?
