モデル番号A1136/30、60、80GBハードドライブ/ブラックまたは白のプラスチックフロント
865の回答 すべて表示
Why is my iPod classic corrupted and not restoring or formatting?
I just purchased a 30 gb ipod classic 5th generation with a weak battery and a dark spot on the screen. It played fine when I first tested it but the hard drive would make clicking noise when turned on and changing tracks. The battery only lasted about 4 hours. I was going to change the battery and screen and thought I might as well replace the hard drive as well since it might be going bad. So I upgrade the 30 gb hard drive with a new 60 gb along with a new lcd screen and 850 mAh battery and thick back cover. Used the same motherboard which was working before and the headphone jack and hold switch that was on the used 60 gb cover. No problems with the changeover and putting it back together. When I turn it on it says to connect to computer and use itunes to restore. I connect to computer and open itunes. The ipod doesn't show up. I unplug it and says the ipod is corrupted and needs to be restored before using with itunes. So it only recognizes it when I unplug it. The computer shows it as an ipod when plugged in and says it needs to be formatted. When I try to format after a minute or so I get a message that it was unable to format. I try a few more times to format but get the same thing. So what could the problem be? The larger capacity hard drive should be compatible. They go up to 60 gb. Should I try to go back to a 30 gb?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
It also has itunes froze up when connected.
による
Nobody has a clue?
による
did u go to the apple store and ask?
による
コメントを追加
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
当社のショップを閲覧する
1回答
最も参考になった回答
jdennis61 I'd be looking at two possibilities. Hard drive and/or logic board. Make sure the dock connector is clean and that you have no bend, broken or corroded pins. Clean the dock connector with some isopropyl alcohol and a few puffs of compressed air. I am sure you already tried a different computer and different cables as well. After that you will have to check the hard drive. For that I'd get an inexpensive Zif-to-USB connector (I use one of these) and use the hard drive as a external drive on any windows based computer. With that you can check to make sure that you have full access to the drive etc. Yes, your iPod should have no issues with a 60GB drive.
この回答は役に立ちましたか?
スコア 3
コメント:
But it's a brand new hard drive and there were no issues before I made any changes. The motherboard should be fine.
による
Right now you are making assumption like the motherboard should be fine or that the drive is new. It is new to you but may be old stock. Test it and see what you get.
による
コメントを追加
回答を追加する
jdennis61 さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 384
