メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Dropped and is completely dead
So i was using my iPhone 6 when cleaning out the fan of my Macbook Pro as a light source. I was sitting in my bed and it slipped of the side of the bed. It dropped and the flashlight and screen immediately switched off. I opened up the phone to check if it was just the screen that had disconnected, i also checked the battery. My phone does not respond to home+power, the mute switch, turning on or charging. I also tried to get a software to detect the phone when connected but even that didnt pick it up. I have no idea what to do. Does anyone know what to do?
NOTE: Phone had a broken screen previously
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hello.
Sorry for the trouble you are experiencing. If you are not getting any power even when plugged in, I would recommend that you remove the battery cable cover and check the connection.
Steps 18 and 19 should be consulted from the manual below.
It is possible that even through the connector seems to be sitting properly, it may have come loose. Unseat the connector and then inspect it for any damage. Reseat the connector carefully and then power the device on.
iPhone 6のバッテリーの交換
I would love to know how it turned out for you. Please don't forget to reply back.
Regards,
Michael
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
marcogronn さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,985
