Why my digital clock on my mileage shows only zero's (0000)?
My clock shows only zeros even without separator. I tried to unplug the plus of my battery for 15 minutes but still nothing. The button for change the hours and the minutes working ( i hear the click and i feel it) but nothing happens., the clock shows only zeros. Why is that?
Hi,
Just curious, are you sure that you have selected the 'clock' to adjust the time and not another option e.g trip meter etc? Normally there is a separator between the hours and minutes.
jayeff さんによる
Yes, I am sure for everything that I wrote. I dont know how can i post a photo of my clock to show exactly whats going on.
Martin Kostadinov さんによる
Hi,
Here is a link that shows you how iFixitでの質問に画像を追加する方法
jayeff さんによる
Link to image
http://imageshack.com/a/img924/4606/Mzi5...
Hi,
Your image shows the zeroes. I'm sorry but maybe I'm thinking of the wrong model. The one that I know you can you select the clock as an option to show by turning the ignition switch to the on position (do not start the engine) and seeing if clock (time) shows as one of the options to select in the middle display window between the dials? You select it by moving the same stalk on which the buttons are. The time appears , as yours does, in the tachometer dial.
jayeff さんによる
2件以上のコメントを表示
