it just shut down, no power
it's a campbell hausfeld welder model ws28000
Can you hear it hum ? If not you probably blew a fuse in the unit. Hopefully you checked the breaker panel to make sure you didn't trip a breaker. If you do hear a hum ,you have power . It may be you lost your ground , but if you are not familiar with high voltage I would get someone who is.
このアンサーは役に立ちましたか?
It could also be that the thermal overload has tripped. With cheaper stickwelders, they over heat a lot. When this happens, let the unit cool down and the thermal overload reset.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 302
