Logicboard replacement; new thermal grease/compound?
Hello fellow diy-people,
Is it smart/necessary to put some extra/new thermal compound between the heat-sink and the cpu/chipset??
thanks in advance!
Guido
この質問は役に立ちましたか?
thanks in advance!
Guido
この質問は役に立ちましたか?
I wouldn't do it unless you're running hot.
Here's a guide on doing it: 放熱グリスの塗布方法
このアンサーは役に立ちましたか?
Agreed +
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 3,537
2 件のコメント
Well, after investigating the situation inside the MBP, It was necessary to remove the old grease because it was kind become solid-ish....so removed the old compound with special cleaner, then added new "Artic silver 5" and everything runs as new! Did two laptops, and this step is necessary. Old stuff doesn't make a good connection with the heat-sink. Thanks for the comments!
Guido
iFatamorgana さんによる
Thanks for accepting the answer, glad I could help.
mayer さんによる
