メインコンテンツにスキップ
New N Series notebooks feature ATI Stream GPU general processing for faster performance. Working together with graphics optimization suite Video Magic, these technologies accelerate multitasking and enable better quality multimedia
Error when open a file in illustrator cs2
When open a file that is worked for 2 days, the illustrator show an error box:
Can't open the illustration. Could not complete the requested operation.
Then the opened file has only a blank layer.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
Thank you buddy for your help and time. your recommendations are very useful. the issue is resolved.
さんによる
コメントを追加
1 件の回答
ベストアンサー
It sounds like it got corrupted then. I doubt you will be able to do anything to recover it… But at least you have the option to try to save the information from the file using Illustrator Recovery Toolbox. http://www.oemailrecovery.com/illustrato...
Are you working off of a local hard drive or across a network to a file server? You might have some issues with your network if it is the latter.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I hope this posts will help you also.
http://yourfriendlyitconsultant.com/2009...
さんによる
コメントを追加
回答を追加する
georgecarroll さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 25
過去 30 日: 126
今までの合計 4,947
