head phone jack repair
how do I know if it's a thick or thin version? I need to replace the headphone jack
Stephen LaScola you could use a kitchen scale and weigh your iPod The "thick" is ~5.7ounce's/163g and the "thin" is ~4.9 ounce's/137g. Check your serial number on this site and see what it tells you.
このアンサーは役に立ちましたか?
Depends on your capacity.
If i'm not mistaken, the 80GB is the thin version, while the 120GB is the thick version.
このアンサーは役に立ちましたか?
Well that is either a 2nd or 3rd GEN I think that you should get a new one
このアンサーは役に立ちましたか?
minecraft pro good game why would you suggest to replace it? If you can fix it there is absolutely no reason to get a new one. Also, there is absolutely no reason for people having to text you to receive an answer. We answer questions on this forums so everyone benefits
Because it takes up too much data to be online 24/7
Whoa, neither your answer nor your comment makes any sense. You may want to review what you are saying. iPod Classic "too much data to be online 24/7" does not compute.....
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 121
