Black Vertical lines after cleaning LCD
Hi, I was wondering if anyone has done OCA repaid on iPhone 5S LCDs. I have a problem that I remove the glass and it's fine but as soon as I clean it I get black vertical lines. Anyone knows why?
I am pretty sure you cracked LCD. I used to have a lot of this issue as well. Sometime iPhone LCD didn't show cracked right a way.
- for iPhone, better remove polarize most of the time. for me i replace polarize for almost every time. iPhone 5/5s LCD can't handle too many pressure. so try to take time and don't give too many pressure when you clean up.
There is polarize glue remover (8222 250ml Polarizing film remover) but can't buy anywhere in US at the moment. Most people use blade.
I would say 80% LCD cracked when you take frame off from the phone. (for 6 and above model)
このアンサーは役に立ちましたか?
hi mate. yeah, i was thinking its cracked or the flex, cant buy any of the machines here in Australia. mine came from china. insted of using the glue remover i use a plastic blade to clean the glue seems to work now. iphone 6 and up can handel the glue remover but not the 5 series. thanks for the help, appriciate it. it ccomfirms what i was thinking.
You are more than welcome. Using the 8222 remover is a magic. Only 20 sec and it peel it off and nothing left. You can ask OCA Master from China. The manager speak English.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 132
