メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
external speaker and headphone jack doesn't work after replacement?
I replaced my iPhone 5S battery but when I was opening the screen the second time to make sure everything was ok, I opened it a little too hard and ripped the touch ID cable, which I know is bad and I will never be able to get touch ID back, but I've accepted that and moved on. My problem now is that the internal speaker works fine, but the external speakers don't work and neither do headphones when I put it in the headphone jack. How is this possible? PLEASE HELP
THANK YOU
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
3 件のコメント:
Just to make sure, is the phone charging? could be a faulty charge port flex or not plugged back into the main board correctly.
さんによる
yes, it's charging, but now the sound works with headphones plugged in, but the sound only comes out of the left ear and i tested it with multiple headphones
さんによる
If you can, i'd probably suggest disconnecting the charge port flex and trying another one (if you can) i know its not ideal but probably the best way to eliminate the charge port flex as the issue.
さんによる
コメントを追加
1 件の回答
Hi Leili
Graig is right it is most likely headphone jack is damaged and disconnects the speaker and microphone. If you could change that it may work. Be careful with your touch ID if you update your software with itunes Apple will brick your phone because the home button is not the original one. You will get error 53 and cannot use your phone any more.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Leili Moradi さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 138
