メインコンテンツにスキップ
Released June 2014, identified by model number B051.
33回答 すべてを表示
beats rights side stopped working
The right side of my beats randomly stopped working and I need to fix them
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 14
2 件のコメント
A repair for the right side would be so greatly appreciated.
さんによる
99% of the time this occurs with the solo 2 model, it is due to a torn internal wire. Check out Joesge.com to get your headphones repaired for a reasonable price. As simple as filling out a service sheet with steps to get them shipped in.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
After doing much research about this. I too have the same problem and found out that the wires on the right side are more vulnerable to getting pinched and freyed due to lack of protection unlike the left side. You can repair it on your own by re saudering the wire to the connector or calling an electronics store to see if they fix headphones. If you need help fixing it yourself look up helpful videos on YouTube. Good luck!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Dylan hammknd さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 13,140
