96 jeep horn replacement
I have a new horn that is compatible with my model but it has different wires. no videos anywhere on the switch. help please!
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If there are 2 wires coming off the horn and 1 wire into the horn then you need to ground the horn to the jeep body. If theres only 1 wire coming off the horn and 2 wires coming in then you need to create a ground by drilling a hole in the base of the horn and attaching the ground wire coming in there . Hope this helps
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 910
