Replaced battery, white screen, very warm
I just replaced the battery on my old 4th gen iPod photo. Now all I get is a white screen and the unit is very warm. Played with the hold switch, but doesn't make a difference.
Any ideas?
この質問は役に立ちましたか?
Any ideas?
この質問は役に立ちましたか?
Brian
After replacing the battery and getting the heat and blank screen, I've just replaced the logic board ($30 approx) and my Ipod is on my desk charging normally. I trust it will work OK when charged. Much cheaper than buying a new one (and I don't want to watch videos on a tiny screen!)
Good luck
このアンサーは役に立ちましたか?
No but I have exactly the same problem.
Before replacing the battery the Ipod wouldn't switch on and the display showed the empty battery symbol (including when I tried the reset procedure). It was working fine a fe minutes before it stopped.
When I tried charging it the hot spot is around the headphone socket and then the screen gets hot.
Cheers
このアンサーは役に立ちましたか?
I replaced the screen a few months ago so I don't think that's the fault. The screen cost approx. $14 (yep, fourteen) USD and took me 15 mins.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,803
